It is currently Fri Jun 21, 2019 1:07 am
Post new topic Reply to topic  [ 266 posts ]  Go to page 1, 2, 3, 4, 5 ... 14  Next
PostPosted: Tue Dec 09, 2008 10:42 pm
Drives: 2litre Si
    having spent the last 6 months stripping out as much weight as possible, ive just gone and got myself a second hand 6 point roll cage weighing 36kg!
    Having done a few track days this year thought is was worth the weight gain for safety and stiffen up the shell.
    the counter the extra weight ive also got some ZX9R motor bike carbs to fit and a OMEX programmable ingition ECU wich hope will push it to 155-160bhp
    Image :)
    PostPosted: Tue Dec 09, 2008 10:46 pm
    Drives: FSI 1.6
    Sweet as a brazilian but
    'Sideways Always'
    PostPosted: Tue Dec 09, 2008 10:55 pm
    looks like you have some serious fun coming your way next year :devil:
    PostPosted: Tue Dec 09, 2008 10:56 pm
    Drives: Mk1 FRS and FRST
    Awesome, good look with the fitment mate! :thumbsup:
    PostPosted: Sat Dec 13, 2008 9:33 pm
    Drives: 2009 Golf 2.0 GT TDI
    The cage is quality will really stiffen the chassis as well as adding safety good work :thumbsup:
    I'll got no chance of catching you now! :lol:
    Tied
    PostPosted: Sat Dec 13, 2008 9:40 pm
    unfortunatly the bolt in cage wont add much stiffness.
    is it a
    bolt to existing place ?
    bolt to existing place with strengthing plate
    or bolt to a fabricated mount?
    PostPosted: Sun Dec 14, 2008 11:09 am
    Drives: 2litre Si
    is it a
    hope it will add a bit of stiffness, Im bolting it in to MSA blue book race regs on steel reinforcement plates and also looking at adding additional 4 mounting points, door pillar upper seat belt mounts and front of roof as the OMP 10 point cage. just wondering if to also fit door bars or not.
    PostPosted: Fri Dec 26, 2008 11:05 am
    as a minimum for safety you need reinforcement plates welded to the floor as the last thing you want is to roll it and the cage punts holes in the floor. as for door bars. personally i would. but some people bitch and moan that its a pig to get in and out of. depends how much of a sacrifice you want to make really. ;)
    Ben.
    PostPosted: Fri Dec 26, 2008 2:38 pm
    Drives: 2litre Si
    bit of a change in initial plans having rather than the carbs now also got some GSXR throttle bodies, so going to go down the route sk8xtrm did http://www.fiesta-si.com/forums/viewtopic.php?f=5&t=11840&st=0&sk=t&sd=a&start=90
    will get it all fitted and hopefully some before and after rolling road runs to see the differance
    PostPosted: Wed Dec 31, 2008 6:23 pm
    Drives: MK1 Focus Estate Ghia
    Be nice to see how much power they add by doing it with the maf etc
    But as you have the omex then why not use that with the gsxr?
    PostPosted: Thu Jan 01, 2009 7:27 pm
    Drives: 2litre Si
    the OMEX ECU i have is a ignition unit only not the more expensive fuel and spark, depends on how it goes if it seems the standard MAF and ECU are holding it back may have a try at Megasquirt ECU
    PostPosted: Sun Jan 18, 2009 6:22 pm
    Drives: 2litre Si
    just spent the day scraping out some of the sound deadening, removed 3.5kg of the stuff just from the front so far with the boot and rear seat area to do must be 8-10kg in total. that will go some way to counter the weight of the cage.
    PostPosted: Sun Jan 18, 2009 10:19 pm
    Good work, looks like a real nasty job though, will it all be ready for the 27th Feb?
    Tied
    PostPosted: Sun Jan 18, 2009 10:33 pm
    Drives: 2litre Si
    27th is still (only) 6 weeks away!, just got to paint the cage and weld on the plates,
    and bolt it in, but currently waiting for another manifold plate so i can fit the throttle bodies. There is still a good chance
    PostPosted: Sun Jan 18, 2009 10:46 pm
    Plenty of time!!! Should be getting mine fixed in a couple of weeks, took it out of the garage today and it started first time!!
    Will drop you a note during the week to make arrangements for my strut brace if thats ok.
    Thanks
    Tied
    PostPosted: Sun Jan 25, 2009 6:23 pm
    Drives: 2litre Si
    Removed the rest of the sound deadening stuff today think there was about 7kg in the end. Also welded in the strengthening plates for the roll cage, these must be two of the worse jobs. Wouldn’t want to fit a cage into a decent car after all the scratches Ive caused :( :(
    PostPosted: Sun Jan 25, 2009 8:02 pm
    Lookin good there mate! :thumbsup:
    Can't believe how much that sound deadening weighed overall, you wouldn't think it!
    PostPosted: Sun Jan 25, 2009 8:19 pm
    Looking good, some good welds there.
    I take it from you mentioning the scratches you had problems getting it into the car!!
    Tied
    PostPosted: Sun Feb 08, 2009 10:29 pm
    Drives: 2litre Si
    finally got the roll cage strengthening plates welded in and part fitted, it was interesting welding 3mm plate to a 14 year ford floor pan!
    PostPosted: Sun Feb 08, 2009 11:27 pm
    Lookin really good there mate! :thumbsup: Love the fiesta-si.com sticker too!
    Will be awesome when its done 8-)
