Fiesta-Si.com • View topic - ST170 Mk2 Fez - Another shell and more bits
It is currently Thu Jun 20, 2019 2:58 pm
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
PostPosted: Thu Dec 10, 2015 10:04 pm
Yes still got the Focus, been working on developing the car past year. Runs with a fully forged , engine with headwork and cams, and external oil pump kit etcc..... . Had it live mapped at Sabre Tuning in Bristol and has 3 maps low medium and high, with a big HP figure of 422bhp and 407ftibs, goes well lol.
Still doing plenty track days, and went to Spa Francorchamps in Belgium last year with it, was mega, some good videos on You Tube chasing Porsches and E92 M3s
PostPosted: Thu Dec 10, 2015 10:15 pm
PostPosted: Fri Dec 11, 2015 9:07 am
focus sounds like a bloody animal :lolz:
PostPosted: Wed Feb 17, 2016 2:48 pm
right so it's about time i got my finger out and updated this thread :D
sooo from the last update a few bits and bobs have happened
i bought a neptune connector for my engine loom
by , on Flickr
i modified a fiesta si throttle bracket to fit on my bodies
by , on Flickr
got my injection tank ready to be fitted
by , on Flickr
i popped out a plastic bung under the rear bench and fed the connect for the fuel pump under the car, the bung fitted perfectly into the now open hole
by , on Flickr
by , on Flickr
i then dropped my old tank
by , on Flickr
injection tank fitted
by , on Flickr
gave the battery tray area and support bars a lick of paint, fitted the rad (which leaks) and coolant hoses
by , on Flickr
i bought and fitted a new header tank
by , on Flickr
by , on Flickr
ive also bought a wideband and egt set up for when the mapping starts
by , on Flickr
spent a bit of time mounting a 2wd cosworth fpr and a fuel filter
by , on Flickr
by , on Flickr
over christmas my loom was started, much love alex :D
by , on Flickr
by , on Flickr
by , on Flickr
i choppped a hole for the neptune connector so i would be in the right place for the xr2 glove box
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Dash is back in, just need to get the relays mounted and the ecu secured and back in place
by , on Flickr
connected the ecu up and checking things before she fired up on the button
by , on Flickr
short video of it firing up with no exhaust and a misfire
https://youtu.be/CF5YMXDlGn4
got my breather fitted , but im not happy with it so it's being re done
by , on Flickr
I've also get a set of 888's ready to go on some pots
by , on Flickr
I made a start on some det cans too
by , on Flickr
got my xr2 arb drop links fitted
by , on Flickr
by , on Flickr
the fez is currently having its exhaust sorted ( the back box is just resting in place on the rubbers in this pic)
by , on Flickr
I've also collected this little stash from mr c6rwn
pot's with A048's, adjustable front end, another mondeo sero, xr2 shafts, steering wheel with a snap off boss and a few bits for my brothers xr2
ive got another fuel system to fit as well, so the system will be redone with quip fittings
by , on Flickr
PostPosted: Mon Feb 22, 2016 10:23 am
awesome work mate ;)
PostPosted: Mon Feb 22, 2016 5:33 pm
It's really taking shape now mate! Made up to hear it run lol
Cracking work !
PostPosted: Sun May 01, 2016 9:19 am
I should really update this thread :hsugh:
PostPosted: Thu May 05, 2016 12:30 pm
Yes...yes you should
PostPosted: Wed May 11, 2016 10:25 am
PostPosted: Fri Aug 19, 2016 8:35 am
You really should bloody update it now!
PostPosted: Fri Aug 19, 2016 9:12 am
Yeah im working on it :hmm:
PostPosted: Wed Sep 14, 2016 9:29 am
Thought it was about time i updated this :lol:
The fez was sent off around January time to have my exhaust sorted out by a local company to me, i had a egt and wide band bosses welded into the manifold while it was there as well as a flexi pipe
by , on Flickr
by , on Flickr
while the fez was away getting the exhaust done i ordered up some an-10 fittings for my breather and rocker cover, i had my spare rocker cover sent off to be converted and the breather had the fittings welded on :thumbsup:
by , on Flickr
my airtec rad also arrived while the exhaust was getting finished off
by , on Flickr
by , on Flickr
ordered a new rocker gasket, some crackle paint and a an-10 converter for the rocker cover
by , on Flickr
by , on Flickr
by , on Flickr
got the fez back mid Jan from having the exhaust done
by , on Flickr
had a v-band added to the mid section to make removing it a bit easier
by , on Flickr
then moved onto fitting my snap off boss and wheel
by , on Flickr
by , on Flickr
ordered up some new brake hoses front (and rear)
by , on Flickr
wrapped the manifold too
by , on Flickr
fitted my airtec rad and the manifold back on too
by , on Flickr
by , on Flickr
test fitting/routing the breather hosing
by , on Flickr
sprayed the rocker cover and touched up the breather too
by , on Flickr
fitted
by , on Flickr
hooked up my throttle body balancing tool
by , on Flickr
alex and i had a minor tinker with the map to get it so i could drive it, check my ghetto gauge holder :lol:
by , on Flickr
got it idling perfectly in the end
by , on Flickr
mid map tweak with the plx wideband going and my LM-2 hooked up ghetto stylie too and the balancing tool just chilling on the windscreen
by , on Flickr
shall update again once i've uploaded some more picsn :wth:
PostPosted: Wed Sep 14, 2016 10:43 am
i then found my my 1.1 mc/servo was completely shagged as no brake fluid was getting to the passenger side front or rear :lol:
sooooo out with the old 1.1 shizzle
by , on Flickr
in with the mk1 mondeo mc/servo, i also tucked my breather behind it nice and neatly
by , on Flickr
then went onto the remove all the 1.1 brakes and fit my wilwoods
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
fitted new drums, wheel bearings, xr2 rear cylinder
by , on Flickr
bled the system with RBF600 fluid..... WTF!!
by , on Flickr
did all the prep work for my mot, emissions on a base map that we knocked up in a chicken shed :lol:
by , on Flickr
alex spent a few hours cleaning the fuel map up on the road, i sourced some bits to make a home made set of det cans and another friend sorted me out with a cable connected to my standard knock sensor so we could work on the ign side of things
by , on Flickr
LM-2 connected up for mapping duties
by , on Flickr
Home made det can V.1
by , on Flickr
sadly the car is so loud on full chat that you cant hear any det so we left the ign side of the mapping alone
in the mean time i ordered a set of harnesses
by , on Flickr
got them fitted
by , on Flickr
as id done a fair few road miles i dropped the cheap oil i used to flush everything out with and replace it with decent stuff
by , on Flickr
got some track plates sorted too
by , on Flickr
ive also sourced a set of xr2 steelies and gave them a lick of paint
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
i've managed to complete at least 1 track day in the fez so far ( which was my first ever track day) , it was awesome ! got 1 more lined up before i drive it to the nurburgring
few pic's from my track session and a slow video of me out on track as i was black flagged for noise on my second session :lol:
by , on Flickr
by , on Flickr
by , on Flickr
my black flag :lol:
by , on Flickr
youtube video
https://youtu.be/7m1BEIGHogk
next steps for the fez over the winter
-fit my swirl pot and external pump
-run new fuel lines
-fit a fuel pressure and oil temp sensors so my ecu can see what's going on
-have the sump modified for a oil return for the breather and a oil temp take off
-replace rusty bonnet
that's about it for now
PostPosted: Wed Sep 14, 2016 3:52 pm
Nice updates there :thumbsup:
PostPosted: Sat Oct 22, 2016 3:32 pm
cheers buddy , there are a few more to do but i'll wait for a bit :lol:
car also got featured in the Nov 2016 issue of Retro Ford :thumbsup:
PostPosted: Mon Oct 24, 2016 9:51 am
I saw your latest "update" on facebook :lolz: :lolz:
Nice one on the feature though :thumbsup:
I've got a sink full of coolant hoses with your name on them in the garage. Will whatsapp you in a bit to check your address :thumbsup:
PostPosted: Tue Dec 20, 2016 10:31 am
what's the update? :halo:
Feature was good - fair play mate ;)
PostPosted: Tue Dec 20, 2016 10:52 am
I still need to sort it out :wth:
Car is in bits again but running for now.... : :lolz:
PostPosted: Tue Dec 20, 2016 11:56 am
PostPosted: Wed Jan 25, 2017 12:00 pm
